AS3933 antenna tuning
Hello everyone!
I hope someone tried AS3933 in their projects to help me.
I use internal RC to generate frequency. (XIN t0 VCC)
And I use R16 <2…0> to tune the antenna with internal capacitors. And it never works. There are no signals on the DAT. I can see the RC frequency on CL_DAT, but the RC tuning based on the LC1 circuit and the Calib_RCO_LC command also does not work. This can be seen by status in R14. I tried everything I could, but no configuration had any effect.
If someone knows what the problem is, please tell me.
Thanks.
I know it’s an old thread, but I’m just facing the same problem. Did you manage to overcome that somehow?
Thanks.
hello, have you get the AS3933 antenna tuning working in your project ?
@andrvisht hello, have you get the AS3933 antenna tuning working in your project ?
Hello @martin.tessier,
We have no information other than the Application Note: AS3933-AN04 – Design Guide
Yes I know, I’m in touch with ams support. Hope we can finally get an answer to this topic.
