Assembly of the ZE064W Series of Connectors from Hirose
We frequently get questions regarding proper handling and assembly instructions for the ZE064W series of rectangular connector housings from Hirose Electric Co Ltd such as the ZE064W-8DP-HU/R(A). We reached out to Hirose on this one and they responded with the following:
The customer definitely should configure their assembly process in a way that prevents the panel seal from being touched intentionally or accidentally. The panel seal for PN ZE064W-8DP-HU/R(A) is not sold separately and does not have its own orderable Hirose part number. PN ZE064W-8DP-HU/R(A) comes with the panel seal already assembled to the housing as shown in the illustration above.
They also included documents for assembling the product, please refer to these documents for a more in-depth discussion of the assembly process.
ETAD-T0947-00.pdf - Handling Manual (2.2 MB)
ETAD-T0670-00.pdf - Instruction Sheet (944.0 KB)
For contacts, tooling, and accessories for this series of connectors please use the links below.
Rectangular Connector Contacts | Rectangular Connectors | Electronic Components Distributor DigiKey
Crimpers, Applicators, Presses | Crimpers, Applicators, Presses | Electronic Components Distributor DigiKey
Insertion, Extraction | Electronic Components Distributor DigiKey
ZE064W-WCP(2022) Connector Polarizing Device (Key, Plug, Post) For ZE064W Series
