I am looking for some assistance in identifying this terminal block and seeing if there is an option for an assembly or alternative part number that would allow a 5.5 x 2.1 mm female barrel connector instead of rising cage clamps.
The looks like a Molex Eurostyle - close to DigiKey part WM26020-ND, but I would like to be sure.
The best match that could find so far is Dinkle’s 2ESDVM.
You may need to measure the terminal pitch in order to ensure the compatibility.
Usually euro-blocks from different vendors do mate, as long as the pitch is correct.
robert.clark
Thank you for contacting Digi-Key , sorry we do not have any pluggable type like this with a 2.1x 5.5 mm barrel connector instead of a clamp style connection , below is a link for what we have to offer in 3 position , you will have to narrow it down with the pitch you need .
