Automotive Relay
Hi
Could anybody help please?
Would the TE Relay V23132-A2001-B200 be a suitable replacement for my camper automobile Relay Ford V23132-A2001-X10?
Any help gratefully received.
David
Hi dirish,
Welcome to the TechForum.
Unfortunately, I could not find any documentation for your particular part number.
I did find this datasheet - ENG_DS_V23132-X0000-A001_1403.pdf (558.2 KB) - which covers a few of the standard variations of the V23123, but does not mention yours. It could just be a proprietary part number for Ford of a standard part, but it could also be a custom (“bespoke” for those of you across the pond) part with some modification from one of the standard options.
Perhaps one of the Ford-focused forums might be of some help there.
Thank you for looking into this for me.
Unfortunately I could not open the datasheet and also this refers to V23123 but my Relay is V23132.
There are some other numbers on my Relay; BA2PA
YS6T 14N029 AC
V23132-A2001-X10
01484
Does this help to discover if
TE V23132-A2001-B200 Is an acceptable substitute? I’ve attached a photo showing the numbers on my Relay.
Thank you for any advice you may have.
David
Hi dirish,
Sorry about the bad link to the datasheet. I have corrected it above.
Unfortunately, the other markings don’t help, as we have the same situation as previously described. Physically, 2-1414939-2 looks right, but I have found no way to know whether the internal circuitry is identical or not, nor whether any differences, if any, are significant.
