I need to replace the pictured battery. I am very unfamiliar with these sort of things so any help would be greatly appreciated.
I believe that it has soldering tabs and the length of the battery is 5.75 inches, if that matters.
I could not find an exact match using the information found on the battery and am simply trying to ensure I order an approximate replacement.
Thank you!
I think that is a pack of 3 series connected NiCad “C” cell batteries.
These should work:
https://www.digikey.com/short/vd9vdfbz
Those have a different voltage. Would that matter?
Also, I do not think the batteries you listed have soldering tabs.
Again, I am a complete novice but I’m trying to learn. Thank you!
Hello sportslover323,
One of the batteries that PaulHutch offered, will have the solder tabs, which is 3145-N-3000CRT-JP-ND. These are 1.2V, so 3 in series will be 3.6V.
