Sub: BMS Fuse Identification
Ref: HP Laptop Battery
PN: 432974-001(HP Spare Replacement Battery PN)
SERIES HSTNN-UB33
FUSE Marking: 12AH4 SC\SF
Size: ~3mm x 5mm
Type: Solder Bridge w/heater, 3/4 pin?
The attached pictures are from a HP Board Management System(BMS) for a 4s2p 18650 cell configurtion. Searching on the marking of ’12AH4 SC\SF’ was not successful.
Well looking on the Internet I find it is possibley a 12A , 36 volt fuse. I would say most likley fast acting. It appears it is protecting an IC. I did not see any size listed so I went by what you listed. I did not find anything on our website that is 12A and that size. I kind of looked if there was anything close to the size. I had no luck. I would like to see if anyone else would find something different. Just in case what I found is not correct.
I agree with @Verna_1353. This does appear to be the 12A 36V SFH-1412A. If Digikey doesn’t carry them, you should have no problem finding them for sale elsewhere online.
And if you are interested, there’s a lot of good information about these fuses here.
