We recently had a customer call in for parts matching the BOM of materials for this project and I thought others might be looking as well. If you are not already familiar with this project you can find the files and information here: GitHub - bwack/Versa64Cart: C64 Single EPROM cartridge pcb
Below is the BOM
- PCB - Can be ordered through our PCB Builder using files from GitHub.
- 100nf ceramic cap pitch 2.54 package c-2,5 - 399-9859-1-ND
- 10k through hole resistor - 13-MFR-25FRF52-10KCT-ND
- 1N4148 diode - 1N4148FS-ND
- 27c512 - AT27C512R-70PU-ND
- Socket for AT27C512R-70PU-ND - 2057-ICS-628-T-ND
- pin header 3x1 with a 2.54 pitch - 732-5316-ND
- pin header 3x2 with a 2.54 pitch - 732-5295-ND
- jumper with a 2.54 pitch - M7581-46-ND
- dip switch DIPSW-05V - CKN3004-ND
- JTP-1130 6x6mm Tact switch - 486-3462-ND
Use the link below to put all items on the BOM (except the PCB) into a DigiKey shopping cart.
Pre-Built DigiKey Shopping Cart
Some of these are alternatives so as always, please review the datasheets to ensure they will work in your specific project.
There are also some great videos on youtube for soldering and assembly instructions and demonstrations.
