Cable for HIF6-40D-1.27R(20
------Question for HIF6-40D-1.27R(20) Please Put your question below------
What cable I should I use with the HIF6-40D-1.27R(20
Here is a list of possible cable options to use with this connector.
Thanks, but not sure that will fit.
I think this connector need 0.025 pitch flat cable, because they are 2 row of 20 x 0.050 connections on this connector.
Normally that would be true but in this case its a dual level IDC connection so it is in fact 0.05inch (1.27mm) pitch cable needed for this.
I think the problem with the suggested cables is I believe this connector would use Quantity 2 twenty conductor cables at 1.27mm pitch.
