I am looking for a cam lock that has weather proof seal and a internal shaft to turn a hexagonal lock drive hole.
Hello @pedalectrichybrid
Welcome to the TechForum
I found 0401116800002 which used a hexagonal lock and has a rubber gasket for its seal.
Hello Anthony,
Thanks for your email. I think there mahaps a miss understanding. What i need is a high security barrel cam style lock with the inside end pin to fit a 8mm hex hole. Not the key being a hexagonal key.
Thank you again for your quick response.
S R Hampton
