Hello JarJarBinks,
Thank you for contacting DigiKey. Unfortunately I am unable to recognize these connectors. If you able to provide some additional close-up pictures from varying angles, we can take another look for you.
Thank you.
JarJarBinks,
Thank you for posting photos on this. They are very helpful.
You are are looking for a flat flex type connector. Here is a link to some parts that are similar to this on our website.
Click here to see similar products
To help narrow the options and look for something that could possibly work we would have to know the correct pitch of the connector and cable that you have.
Click here if you need help finding the pitch
It would also be helpful to have a pictures taken that would allow us to see the connector equally on all sides (3/4 View) so that we can better see some of the features and attributes.
Based on the measurement and the additional images I have found the parts below.
1253-046284006001846+CT-ND
046284006001846+
Kyocera International Inc. Electronic Components
0.5MM PITCH - 6 POS - RT ANGLE -
1253-046284008001846+CT-ND
046284008001846+
0.5MM PITCH - 8 POS - RT ANGLE -
These images are taken of the bottom of the part. If you take a look at the drawing however you can more easily see how this measures up. It is applicable to both of these connectors
I hope this is helpful!
Thank you, I really appreciate it, I believe these will work.
