I am having trouble locating this connector on your website, any help would be greatly appreciated.
Can you measure the pitch of the connector (distance from the center of one contact to the center of the next)? You can measure this on the board-side pins, too, if that’s easier than measuring the wire-side housing. A two-place decimal in mm will help.
Also, what device are these being used with? Does that have a model number?
Thank you for your response,
This looks like an IDC connector - here’s the closest option I was able to find on our site:
https://www.digikey.com/short/wrn4zff0
Please verify and compare the dimensions of your part with the drawing for the above part.
Drawing:
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=179694&DocType=Customer+Drawing&DocLang=English
Thank you very much!
