Capacitor for ssb grounding
Hi all
I am new to this.
I am installing a HF radio on my steel sailboat. For the grounding of the tuner and the transmitter i will install a copper strap connecting both devices to the hull.
To prevent galvanic corrosion i need to solder in between each device and the grounding point 4 capacitators to the copper strap.
I need NPO or COG ceramic capacitators with the following specs:
.1 uF 600 V
Which will be easier to solder for a newbie?
Leaded or surface mount?
Can you post a link to a capacitator type that fits the specs and is in stock?
I am owerwhelmed with all the different types.
Thx
Lukas
Is this a 600VAC or 600VDC capacitor?
Hi Karl
Thanks for the reply.
It should work a a DC block capacitator.
The through hole would be easier to solder. Take a look at this link for part numbers.
Thanks for the reply Karl
Are those ceramic caps?
No, they are film capacitors.
Thanks Karl
My manual says i should use ceramic ones because other “are lossy and can overheat if current is high enough”
Do you have ceramic ones as well in stock with the same specs?
Here’s a search for ceramic 0.1uF 630V C0G, NP0 capacitors in stock.
