The capacitor is from a motherboard: Asus p8z68-v pro
Looking to buy suitable replacement in Canada.
Marking on it:
FP5K
15Ax
8 2 1
0 3
Welcome to the community.
The marking
FP5K = Product logo
15Ax = Lot Number
8 2 1 = 820uF
0 3 = Voltage Code
Datasheet RNU Series Datasheet by Nichicon | Digi-Key Electronics
I believe the 03 voltage code calls out 3V. You will have to use a larger voltage rated capacitor. Compare the options here Aluminum - Polymer Capacitors | Electronic Components Distributor DigiKey for a replacement and make sure the dimensions will work in the application.
