We have purchased 565-1598-ND from DigiKey in the past. Now we need the exact same thing but in 25V @ 100 qty. What would be the correct part # ? We’re having trouble identifying.
Hello @wphoenix. Please take a look at the 493-16024-ND from Nichicon on the following link, USV1E100MFD Nichicon | Capacitors | DigiKey. This was the closest I could find to the 565-1598-ND with a 25V voltage rating, while maintaining the 2mm lead spacing, and 5000 Hour lifetime at 105°C. For a side-by-side parametric comparison of those, please take a look at the following link: Capacitors | Aluminum Electrolytic Capacitors | DigiKey
Why would you need the same part but in a lower voltage? There is no electrical reason to go to a lower voltage part. Do you need a smaller physical size?
David,
Thank you for your input! And yes, the smaller physical size suited our application.
With thanks and best regards,
Dedra Lance
Administrative Assistant
Phone 800.827.2017
Fax 888.898.8974
E-Mail Sales@TuffTread.com
www.TuffTread.com
