I need a Replacement to these capacitors. Do y’all have any?
Hi Daniel01,
Welcome to the TechForum.
Assuming they are both the same value of 80V 560uF (I can only see the voltage and capacitance on one of the two), here is a list of the options we normally stock:
Note that the differences are just the dimensions. They are all the from the same Rubycon ZLH series. Measure the diameter and height of yours to find the one which matches.
