Choosing a PIN Modulator
I need to generate the following waveform and I am not sure what the best tools to do so are:
  • Output Signal Peak Power: ~10 Watts
  • Frequency: ~3 GHz
  • Modulation: Sawtooth pattern at a modulation frequency of KHz to low MHz
I expect that a Voltage Variable Attenuator specifically a PIN modulator will be the best device to achieve this modulation pattern. A variable amplifier may also work. I am not sure which device will best meet our needs. The device does not need to be rated for 10 Watts as we can amplify the signal after it is modulated by the device. What device should I purchase?
