Is their anyone that can ID this connector that goes in a Chrysler caravan powered sliding door track harness??
What is the pin spacing for the connector you are searching for?
Hello @CJBinc04,
Welcome to the TechForum. I’m guessing this is a Delphi Connector from the APEX 2.8mm Series. A compatible part might be part number 54201009. Try searching online for Delphi 54201009
Series photo Example
Datasheet - APEX 2.8 Sealed Series A4 Web.pdf (tti.com)
thank you so much!!! ![]()
Could you tell me who made this??
Hello @CJBinc04,
Could you provide photos of the side, bottom, and back of the connector? Are there any manufacturer logo’s or markings?
Thanks!
I’ve looked through our system, and I cannot match this connector with anything we stock. However, searching based on the part markings does pull up information from Delphi/Aptiv.
I would recommend looking into them to find a match for these connectors.
