Any of the Mini-Fit® Jr™ series below will work with these pre-crimped leads
4 Pin Peripheral Power Connector
This is often generically referred to by PC enthusiasts as a “molex connector” in the same way as one might ask for a certain common brand of facial tissue.
A1431-ND
WM6982-ND
4 Pin Peripheral to SATA Cable Assembly
WM19028-ND
SATA Power Connector
Connectors/Housings
WM3466-ND
WM14670-ND
WM19024-ND
WM3475-ND
Assemblies
WM3623-ND
WM8714-ND
ATX 20 Pin Main Power Connector
Mini-Fit® Jr™ 5557
WM3709-ND
VAL-U-LOK
A30599-ND
A123502-ND
A123525-ND
A123510-ND
A113145-ND
2-1586765-0-ND
AMP-DUAC
2-106527-0-ND
A113269-ND
ATX 24 Pin Main Power Connector
Mini-Fit® Jr™ 5557
WM3711-ND
WM23711-ND
Mini-Fit® Jr™ 46992
WM12773-ND
VAL-U-LOK
A123504-ND
A123512-ND
A120574-ND
A30601-ND
A113147-ND
AMP-DUAC
A113271-ND
2-106527-4-ND
4 Pin ATX +12V Power Connector
Mini-Fit® Jr™ 5557
WM3701-ND
WM23701-ND
WM13487-ND
WM1022-ND
WM4369-ND
WM13116-ND
Mini-Fit® Jr™ 46992
WM16165-ND
VAL-U-LOK
A30591-ND
A107334-ND
A112434-ND
A120455-ND
A123488-ND
A120491-ND
AMP-DUAC
A111773-ND
A114477-ND
8 Pin EPS +12V Power Connector
This connector is often used to provide extra power for high-end video cards.
Mini-Fit® Jr™ 46992
WM16167-ND
Mini-Fit® Jr™ 5557
WM3703-ND
WM23703-ND
WM13488-ND
AMP-DUAC
794657-8-ND
106527-8-ND
VAL-U-LOK
A120457-ND
A112436-ND
A30593-ND
A123490-ND
A112424-ND
A120492-ND
6 Pin PCI Express Power Connector
Mini-Fit® Jr™ 45559
WM10848-ND
