Correct sized connectors
A post on common fan connectors can be found here.
Similarly, one for connectors commonly found in PCs is here.
The contact part numbers given are a multi-use item; they are compatible with several different connector series. A sampling of compatible housings can be found under the “For Use With” heading by scrolling down the product page for each. This is not necessarily an exhaustive listing, but does suggest where more/similar products can be found.
