Can you provide more context to help flesh out how you are expecting the value to be recieved?
What is the sensor?
What is the basic functional diagram of your sensor/microcontroller circuit? (specificly, how does you expect your sensor to get to your microcontroller/arduino?)
What communication protocal are you planning to use? (GPIO/digital, SPI, I2C, etc.)
It should be easier for us to help with this information.
There is an application note here from the manufacturer describing recommended interface circuitry for their various sensor products. A suggested circuit for the SGX-4OX sensor is given in section 4, and amounts to a simple non-inverting amplifier circuit, the output of which can be read using the ADC peripheral of one’s chosen microcontroller platform.
Due to the small signal being measured and low supply voltages involved, selection of a low-offset op amp with rail-rail input & output capability would be recommended, with NCS333ASQ3T2G being an example of such.
