Conventional IC
------Question for TPIC6A595DWR Please Put your question below------I recently made an order for a friend overseas and he sent mail indicating that cannot use the item because what he needs is an IC that has to be plugged in a socket. Is this TPIC6A595 available to be plugged in a socket. Thanks in advance for your response. Mario
If you need something socketed you’ll want to switch to part number TPIC6A595NE
thanks for the prompt response. wonder if this IC is available in United States. Thanks again !
We, DigiKey, are in the United States and at the time I write this we have almost 600 of part number TPIC6A595NE
I am reading on Google that there is an adapter board for what I already bought. I guess it is more convenient to buy the part number you suggest since I don’t know if they will be able to use/solder the IC I already sent them overseas.
thanks, I did not know if you were from DIGIKEY.
don’t recall if when I placed the order I specified that the IC had to be plugged in a socked and did not open the package before sending them overseas. Well it was a small expense anyway. I am awaiting response from friend and probably will place an order for 2 chips if he has not been able to save the problem yet. Thanks for the support ?
The surface mount SOIC version of this chip has 24 pins and will likely not work if they require the 20 pin DIP version of the chip.
this is what he sent me at the time of the order but I forgot to upload the pic, my bad !
