CR7A-KIT packaging
I’m considering the larger CR7-KIT-ND (12200PCS) as an alternative to CR7A-KIT-ND (3050PCS). Can you please confirm if the exterior binder size is the same between the regular and the -A variants?
I own CR6A-KIT-ND and it measures approximately 5.5" x 7.5" x 1" depth.
Thanks,
Kevin
Welcome to the DigiKey TechForum kphamB,
Both the CR6A-KIT-ND (3000 pieces), and the CR7A-KIT-ND (3050 pieces) are listed as book packaging, so they come in the binder. The CR7-KIT-ND (12200 pieces) is listed as Bag packaging. So the resistors will come in bags, and not a binder.
