Dc psu 30V/1,3A with kycon 3pin (KPPX-3P) output
Hi!
Could you help me finding a solution for changing a broken psu with euro connector input (230Vac mains) that can deliver 30V minimum 1.3A with positive on pin 1 and negative on pin 2, (pin 3 NC) on a KPPX-3P connector, without having to modify any cables/plugs. PSU + adapter is ok.
Truls
Hello Trulstam and welcome to the forum,
Unfortunately I do not have such an assembly. You would have to select a power supply and then append a KPPX-3P cable assembly after the fact.
