DE-25 FPGA Dev Kit Additonal Setup Part 1 (Arm Trusted Firmware Setup)
The present article will describe the process for the Arm Trusted Firmware relevant to the DE-25 FPGA Dev Kit,
this will act as the FSBL and SSBL bootloader as described in the following diagram:
To perform this process complete the following,
git clone -b QPDS24.3_REL_GSRD_PR  https://github.com/altera-opensource/arm-trusted-firmware arm-trusted-firmware-sdcard
cd arm-trusted-firmware-sdcard
git switch -c test
make realclean
ARCH=arm64 CROSS_COMPILE=aarch64-none-linux-gnu- make PLAT=agilex5 SOCFPGA_BOOT_SOURCE_SDMMC=1 bl2 bl31 PRELOADED_BL33_BASE=0x80100000 -j$(nproc)
The DE-25 FPGA Dev Kit is a powerful platform featuring an HPS/FPGA Agilex 5 (available as D-Series and E-Series depending on the case) capable of implementing Tensor AI slices,
that go beyond what traditional/classical old school DSP slices implemented in the past,
and it is available at DigiKey.
Have a wonderful day!
This article is available in spanish here.
Este artículo está disponible en español aquí.
