I cannot drive GPIO inout on Atlas DE0 nano soc. A simple test using all the altera privitive buffers show on Signal Tap and the oscilloscope nothing when the GPIO is considered inout. Even when driving not tri-state signals:
entity MasterSlave is
port
CLOCK_50 : in std_logic;
GPIO_1 : inout std_logic_vector(3 downto 0) := (others =>'Z');
GPIO_0 : out std_logic_vector(1 downto 0);
HPS_I2C1_SDAT : inout std_logic;
HPS_I2C1_SCLK : out std_logic;
clk <= CLOCK_50;
process (clk, data)
begin
if rising_edge(clk) then
data_bin <= '1';
if data='0' then
data_bin <= '0';
end if;
end if;
end process;
data_n <= '1' when data = '0' else '0';
control_tri <= '0' when control = '0' else 'Z';
control_n <= '1' when control = '0' else '0';
GPIO_0(0) <= data_bin;
GPIO_0(1) <= control;
I_control_n_GPIO_1_0_iobuf: ALT_IOBUF
port map (i => '0', oe => control_n,o => data_GPIO_1_0,io => GPIO_1(0));
process (clk,data_GPIO_1_0)
begin
data_GPIO_1_0_reg <= data_GPIO_1_0;
end if;
end process;
I_control_GPIO_1_1_iobuf: ALT_IOBUF
port map (i => '0', oe => control,o => data_GPIO_1_1,io => GPIO_1(1));
process (clk,data_GPIO_1_1)
begin
data_GPIO_1_1_reg <= data_GPIO_1_1;
end if;
end process;
I_control_n_GPIO_1_2_tri : TRI
port map (a_in => '0', oe => control_n, a_out => GPIO_1(2));
I_control_GPIO_1_3_tri : TRI
port map (a_in => '0', oe => control, a_out => GPIO_1(3));
I_control_n_HPS_I2C1_SDAT_iobuf: ALT_IOBUF
port map (i => '0', oe => control_n,o => data_HPS_I2C1_SDAT,io => HPS_I2C1_SDAT);
process (clk,data_HPS_I2C1_SDAT)
begin
data_HPS_I2C1_SDAT_reg <= data_HPS_I2C1_SDAT;
end if;
end process;
I_control_HPS_I2C1_SCLK_outbuf: ALT_OUTBUF
port map (i => control,o => HPS_I2C1_SCLK);
