Default SPI Address for MCP3564R
------Question for MCP3564RT-E/ST Please Put your question below------
Where can I find the default SPI address for the 20-TSSOP package of the MCP3564RT chip? The datasheet does not specify how to read the address for the non-UQFN package. Here is a picture of the markings on the chip I have:
Thank you!
Greetings,
While the datasheet doesn’t appear to state this information specifically, it may be noted that ‘01’ is the indicated value for all enumerated variants, and that to order other options one is directed to “contact sales” meaning that the other variants are less likely to be encountered.
In any case, there are only four possible options to try. If none of them yields a result, it is likely that something other than having the incorrect address is the cause of difficulty.
That is true. I think “01” is the only address for the 20-TSSOP package, it seems to work (mostly). Thank you so much for the help.
