Scalability & Compatibility in FPGA SoMs
FPGA SoMs offer excellent scalability and compatibility within a unified ecosystem, enabled by standardized form factors and consistent board to board (B2B) connector interfaces. This architectural approach ensures that multiple SoMs ranging from mid-range to high-performance devices share a common footprint and pin compatibility, as illustrated in the images below.
As a result, designers can seamlessly migrate across different performance variants without the need to redesign the carrier board. A system initially developed using a mid-range SoM can be easily upgraded to a higher-end device by simply replacing the module, eliminating the need for a complete system redesign. This enables a true plug-&-play upgrade path while significantly reducing development effort, time-to-market, and overall design risk.
AMD FPGA SoM Overview:
Altera FPGA SoM Overview:
Key Tip:
No matter the platform, FPGA SoMs allow seamless migration to higher or lower performance variants based on application needs, ensuring flexibility and design continuity
Feel free to share your thoughts or ask any questions.
