DF52-2832PCF
Hi,
Is there on the market a handy applicator for the Hirose DF52-2832PCF 28-32AWG CRIMP
Thanks for your support
Amos
The applicator part number for DF52-2832PCF would be H125110-ND
Thanks for your reply.
Was asking for a HANDY applicator.
Are you sure that your offered applicator is a HANDY one?
Amos
Amos, by “handy” applicator, do you mean a hand tool for the part? I just wanted to clarify the question at hand here. If so, please note that Hirose does not officially recommend any hand tools for this particular terminal. You can try to use a generic hand tool, but we can’t guarantee a quality crimp from those and according to the datasheet, “Issues caused by using tools other than those specified by Hirose are not covered by warranty.” Let us know if you’d like us to suggest a generic tool for this.
Hi Kaleb,
Yes, we are looking for a hand tool for that crimpt.
we understand the warranty issue.
Nevertheless, we would appreciate it if you could try to recommend us a hand tool that might do the work here.
Thanks,
Amos
You can take a look at this list of hand tools that may work for this, click here.
Thanks a lot.
Hi amos,
Contacts that small (sub-millimeter pitch connectors) are extremely finicky and subject to damage or improper seating if crimped with anything other than the recommended tool.
If at all possible, I would recommend using the pre-crimped jumper, part number DF52-2832PF1571-28A9-300, which is a 300mm 28AWG wire harness with a DF52 contact already crimped on each end.
Hi David,
Thanks
