DFrobot FIT0458 or DigiKey 1738-1270-ND
Can someone confirm the construction of the gears? I’m looking for something with metal gears. Can’t figure it out from the data sheets on this product. Thanks!
Hello bcranston and welcome to the forum,
I was not able to verify right away what the material was. I’m checking internally to see if we can verify it for you or not. I’ll let you know what comes back.
The material of the gear is plastic and nylon, not metal.
Thank you for the follow up.
Hi, does the connection cable included in the package? (encoder cable and motor cable)
The motor comes supplied with two cables.
Thank you for the information
