Diode marking code BR
I m looking for Digikey part number of this diode Marking code is " BR"
The “V” designations make me think they are not ordinary diode as diodes usually have designators of “D”. “V” usually denotes a vacuum tube. However the product could be made in country where the word for diode begins with “V”.
If it is an English language designator I’d guess the “V” parts are varistors, although traditionally “RV” is used for the reference designator.
Thanks for replying. Here i.m asking Ng about Diode which display in pic having marking code “BR”
I need it’s voltage rating or Digikey part number for ordering
Hello Imtaoseef, welcome to the Tech Forum. I am sorry, I do not recognize the logo on your diode as a supplier that we have at Digi-key. I was not able to identifiy your diode.
Hello @Imtaoseef,
The part should be SMBJ17CA-FDITR-ND( SMBJ17CA-13-F)
Thank you very much . It is used at drive side (6 pulse cct) with IGBT in inverter . You solve my problem.
