As @Cvanbeek said here - DKRed Incorrectly States Hole Sizes are too big - I can’t upload my gerbers to DK Red, as it throws an error that “Drill hole size must be less than 250 millimeters or less”. Unfortunately, there does not seem to be a resolution in that thread, last response is a DigiKey representative asking for his files for testing
According to my drill file (generated from Autodesk Eagle 9.6.2), my holes are .35mm and .813mm - all the board is is to correct a pin swap from an EOL 28 pin IC, so it’s essentially going to be 2 DIP 28 sockets and some vias.
The image in the preview even seems to pass the sanity check
Drill file below
M48
;GenerationSoftware,Autodesk,EAGLE,9.6.2*%
;CreationDate,2024-04-25T14:18:40Z*%
FMAT,2
ICI,OFF
METRIC,TZ,000.000
T2C0.350
T1C0.813
G90
M71
T1
X17780Y5080
X46990Y30480
X46990Y27940
X46990Y22860
X46990Y20320
X46990Y17780
X46990Y15240
X46990Y12700
X17780Y20320
X46990Y10160
X46990Y7620
X5080Y5080
X7620Y5080
X10160Y5080
X12700Y5080
X15240Y5080
X46990Y5080
X20320Y5080
X22860Y5080
X25400Y5080
X27940Y5080
X30480Y5080
X33020Y5080
X35560Y5080
X38100Y5080
X38100Y20320
X35560Y20320
X33020Y20320
X30480Y20320
X27940Y20320
X25400Y20320
X22860Y20320
X20320Y20320
X46990Y25400
X15240Y20320
X12700Y20320
X10160Y20320
X7620Y20320
X5080Y20320
X62230Y5080
X62230Y7620
X62230Y10160
X62230Y12700
X62230Y15240
X62230Y17780
X62230Y20320
X62230Y22860
X62230Y25400
X62230Y27940
X62230Y30480
X62230Y33020
X62230Y35560
X62230Y38100
X46990Y38100
X46990Y35560
X46990Y33020
T2
X29527Y16828
X33655Y18415
X33973Y16192
X60325Y16192
X50482Y6032
X58420Y21590
X59690Y3492
X48895Y19685
X32067Y24447
X44450Y19050
X16192Y12065
M30
Edited to correctly tag the previous thread OP
