Does LRS-200 include mounting brackets?
I see them in the datasheet with dashed lines but not in the product photo and description. It’s this product:
It says “chassis mount” but could also be referring to the threaded inserts.
perry
Thank you for contacting DigiKey , I do not see that this power supply comes with brackets on the data sheets or the manufacturer web site , the data sheet is just showing the location of the M4 threaded mounting holes .
Thanks Craig
Thanks Craig. I found the brackets after searching around:
