Mounting clips
Salesorder ID . I am looking for the angle clips to mount the power supplies referenced in the about order. Can you make a recommendation
Hi matt2,
Thanks for your inquiry. We try to refrain from putting sales order numbers on this public post. Would you be able to supply the power supply part numbers?
Thank you!
RSP-320-48
1866-4270-ND
AC/DC CONVERTER 48V 322W
Hi matt2,
I believe the proper part number for those clips is MHS012. Unfortunately, we do not stock this part. It can be specially ordered, but there would be a significant lead time and a large minimum order quantity (2000 pcs).
I would suggest you throw that Meanwell part number in Google. You might find someone who happens to stock it.
Thank you for your help!
Matthew L. Oeler
Oeler Industries, Inc.
www.oeler.com
412-884-3000
