------Question for EG21GGBTEA-128-SGNS Please Put your question below------
is this a full dev kit? please recommend antenna for cat module
also could you provide the datasheet , AT commands manual
I am checking on this. Will let you know when I have the answer.
EG21GGBTEA-128-SGNS is not a full dev kit; it is compatible with the UMTS-LTEEVB-KIT(https://www.digikey.ca/en/products/detail/quectel/UMTS-LTEEVB-KIT/13278276)
The antennas are included in the dev kit,
Please refer to the spec and AT command manual attached below,
Quectel_EG21-G_LTE_Standard_Specification_V1.6.pdf
Quectel_EC2x&EG2x&EG9x&EM05_Series_AT_Commands_Manual_V2.1.pdf
