hi thank you so much i need this resistor as well I have taken a few pic of it
That appears to be an older (1970s to 1990s) 560 ohm 1/2W 1% metal film resistor.
Here’s a modern version:
The “J” on there may call out a 5% rather than 1% tolerance, but this is a minor quibble; I’ll second Paul’s suggestion as a good replacement.
hi it a 2w one not 1/2w
In that case you may want to consider:
