Hi, Do 900-0150160665-ND and 900-5019516000CT-ND mate properly?
If not, which set of 60 contact 0.5mm jumper (Same side contacts) and ZIF connector (Vertical) do? (Preferably Molex.)
Thank you for your help!
For the 900-0150160665-ND cable Molex recommends the below connector.
2004850460
2004850460 Molex | Connectors, Interconnects | DigiKey
Also note, that 900-0150160665-ND and 900-5019516000CT-ND could work just that the above connector is listed for that cable by Molex.
Thank you Nathan!
