Finding the correct pushpin and spring for your heat sink can be a tricky task. Recently, Advanced Thermal Solutions (ATS) has come up with a new tool for finding the correct push pins and springs. For this example i will use heat sink part ATS-CPX060060025-132-C2-R0. The tool is on the ATS website.
Step 1
Enter the heat sink information you have. The example heat sink is 60mm x 60mm x 25mm (LxWxH) and I will say i have 3.175mm PCB Hole sizes.
Step 2
Select your part number from the list of parts that is displayed and then click on the Select push pins and springs button.
Step 3
Select your board thickness, component height, and component size and then hit calculate.
This will give you a pin and spring part number. For the example part number using the specifications I choose this would be Push Pin ATS-PP-08 and Spring ATS-PPS-17.
Applicable Part Numbers
ATS1584-ND ATS1357-ND ATS1514-ND ATS1516-ND ATS1558-ND ATS1672-ND ATS1704-ND ATS1604-ND ATS1611-ND ATS1398-ND ATS1723-ND ATS1403-ND ATS1515-ND ATS1517-ND ATS1625-ND ATS1546-ND ATS1547-ND ATS1521-ND ATS1629-ND ATS1628-ND ATS1637-ND ATS1523-ND ATS1525-ND ATS1648-ND ATS1633-ND ATS1528-ND ATS1535-ND ATS1577-ND ATS1588-ND ATS1531-ND ATS1587-ND ATS1699-ND ATS1539-ND ATS1645-ND ATS1540-ND ATS1545-ND ATS1596-ND ATS1657-ND ATS1564-ND ATS1597-ND ATS1619-ND ATS1716-ND ATS1850-ND ATS1605-ND ATS1609-ND ATS1719-ND ATS1610-ND ATS1400-ND ATS1405-ND ATS1640-ND ATS1653-ND ATS1543-ND ATS1594-ND ATS1797-ND ATS1807-ND ATS1795-ND ATS1759-ND ATS1410-ND ATS1404-ND ATS1590-ND ATS1624-ND ATS1552-ND ATS1636-ND ATS1555-ND ATS1641-ND ATS1585-ND ATS1586-ND ATS1536-ND ATS1589-ND ATS1644-ND ATS1616-ND ATS1617-ND ATS1615-ND ATS1620-ND ATS1583-ND ATS1599-ND ATS1601-ND ATS1718-ND ATS1607-ND ATS1606-ND ATS1406-ND ATS1360-ND ATS1359-ND ATS1519-ND ATS1550-ND ATS1627-ND ATS1626-ND ATS1551-ND ATS1660-ND ATS1664-ND ATS1565-ND ATS1638-ND ATS1566-ND ATS1569-ND ATS1666-ND ATS1570-ND ATS1524-ND ATS1669-ND ATS1571-ND ATS1642-ND ATS1649-ND ATS1643-ND ATS1679-ND ATS1527-ND ATS1526-ND ATS1574-ND ATS1683-ND ATS1529-ND ATS1650-ND ATS1685-ND ATS1634-ND ATS1662-ND ATS1530-ND ATS1537-ND ATS1532-ND ATS1533-ND ATS1549-ND ATS1655-ND ATS1591-ND ATS1668-ND ATS1692-ND ATS1541-ND ATS1702-ND ATS1592-ND ATS1553-ND ATS1554-ND ATS1647-ND ATS1646-ND ATS1542-ND ATS1557-ND ATS1556-ND ATS1703-ND ATS1595-ND ATS1670-ND ATS1544-ND ATS1560-ND ATS1706-ND ATS1568-ND ATS1612-ND ATS1561-ND ATS1562-ND ATS1674-ND ATS1656-ND ATS1573-ND ATS1572-ND ATS1659-ND ATS1658-ND ATS1563-ND ATS1777-ND ATS1665-ND ATS1661-ND ATS1690-ND ATS1779-ND ATS1710-ND ATS1618-ND ATS1675-ND ATS1578-ND ATS1579-ND ATS1614-ND ATS1780-ND ATS1581-ND ATS1693-ND ATS1678-ND ATS1598-ND ATS1677-ND ATS1711-ND ATS1783-ND ATS1680-ND ATS1582-ND ATS1600-ND ATS1684-ND ATS1700-ND ATS1796-ND ATS1784-ND ATS1828-ND ATS1830-ND ATS1792-ND ATS1698-ND ATS1829-ND ATS1798-ND ATS1694-ND ATS1831-ND ATS1833-ND ATS1799-ND ATS1832-ND ATS1696-ND ATS1697-ND ATS1835-ND ATS1801-ND ATS1713-ND ATS1800-ND ATS1707-ND ATS1848-ND ATS1836-ND ATS1622-ND ATS1844-ND ATS1717-ND ATS1852-ND ATS1789-ND ATS1790-ND ATS1837-ND ATS1856-ND ATS1816-ND ATS1806-ND ATS1808-ND ATS1817-ND ATS1842-ND ATS1712-ND ATS1714-ND ATS1819-ND ATS1823-ND ATS1725-ND ATS1858-ND ATS1726-ND ATS1860-ND ATS1859-ND ATS1810-ND ATS1727-ND ATS1728-ND ATS1730-ND ATS1825-ND ATS1744-ND ATS1732-ND ATS1868-ND ATS1720-ND ATS1745-ND ATS1746-ND ATS1862-ND ATS1869-ND ATS1873-ND ATS1747-ND ATS1721-ND ATS1794-ND ATS1870-ND ATS1749-ND ATS1748-ND ATS1871-ND ATS1827-ND ATS1875-ND ATS1734-ND ATS1733-ND ATS1752-ND ATS1722-ND ATS1812-ND ATS1738-ND ATS1878-ND ATS1754-ND ATS1409-ND ATS1407-ND ATS1756-ND ATS1739-ND ATS1865-ND ATS1814-ND ATS1758-ND ATS1866-ND ATS1411-ND ATS1412-ND ATS1743-ND ATS1867-ND ATS1761-ND ATS1768-ND ATS1765-ND ATS1769-ND ATS1762-ND ATS1772-ND ATS1763-ND ATS1414-ND ATS1775-ND ATS2225-ND ATS1399-ND ATS1402-ND ATS1401-ND ATS1413-ND ATS1415-ND ATS1358-ND ATS1520-ND ATS1635-ND ATS1608-ND ATS1630-ND ATS1522-ND ATS1534-ND ATS1701-ND ATS1671-ND ATS1580-ND ATS1602-ND ATS1715-ND ATS1815-ND ATS-CPX050050025-124-C3-R0-ND
ATS-CPX050050006-199-C2-R0 ATS-57000-C1-R0 ATS-CPX025025010-137-C2-R0 ATS-CPX025025015-138-C2-R0 ATS-CPX040040025-116-C2-R0 ATS-FPX040040025-05-C2-R0 ATS-FPX050050025-15-C2-R0 ATS-CPX060060025-132-C2-R0 ATS-CPX070070025-136-C2-R0 ATS-1038-C1-R0 ATS-FPX070070025-30-C2-R0 ATS-1039-C3-R0 ATS-CPX025025010-165-C2-R0 ATS-CPX025025015-166-C2-R0 ATS-FPX025025010-73-C2-R0 ATS-CPX040040006-193-C2-R0 ATS-CPX040040010-113-C2-R0 ATS-CPX025025025-168-C2-R0 ATS-FPX025025020-75-C2-R0 ATS-FPX025025020-45-C2-R0 ATS-FPX030030010-79-C2-R0 ATS-CPX030030010-169-C2-R0 ATS-CPX030030015-170-C2-R0 ATS-FPX035035010-55-C2-R0 ATS-FPX025025030-77-C2-R0 ATS-CPX030030025-144-C2-R0 ATS-CPX035035010-175-C2-R0 ATS-CPX045045025-120-C2-R0 ATS-CPX050050015-122-C2-R0 ATS-CPX030030030-173-C2-R0 ATS-CPX050050012-201-C2-R0 ATS-FPX050050010-11-C2-R0 ATS-CPX035035020-177-C2-R0 ATS-FPX030030030-83-C2-R0 ATS-CPX035035025-150-C2-R0 ATS-CPX035035035-180-C2-R0 ATS-CPX054054020-127-C2-R0 ATS-FPX035035030-89-C2-R0 ATS-CPX040040035-186-C2-R0 ATS-CPX054054025-128-C2-R0 ATS-FPS058037023-34-C2-R0 ATS-FPX060060015-23-C2-R0 ATS-P2-13-C2-R0 ATS-CPX070070006-208-C2-R0 ATS-CPX070070015-134-C2-R0 ATS-FPX070070010-26-C2-R0 ATS-CPX070070020-135-C2-R0 ATS-1038-C3-R0 ATS-1040-C2-R0 ATS-FPX030030020-51-C2-R0 ATS-FPX035035020-87-C2-R0 ATS-CPX035035030-179-C2-R0 ATS-CPX054054012-204-C2-R0 ATS-P1-12-C2-R0 ATS-P1-22-C2-R0 ATS-P1-112-C2-R1 ATS-H1-26-C2-R0 ATS-1042-C1-R0 ATS-1040-C1-R0 ATS-CPX050050025-124-C2-R0 ATS-FPX025025010-43-C2-R0 ATS-CPX040040015-114-C2-R0 ATS-FPX030030010-49-C2-R0 ATS-CPX040040020-115-C2-R0 ATS-FPX030030020-81-C2-R0 ATS-CPX050050010-121-C2-R0 ATS-CPX050050010-200-C2-R0 ATS-CPX035035015-148-C2-R0 ATS-CPX050050020-123-C2-R0 ATS-FPX030030030-53-C2-R0 ATS-FPS058037006-31-C2-R0 ATS-FPS058037011-32-C2-R0 ATS-FPS037058023-38-C2-R0 ATS-FPS058061006-39-C2-R0 ATS-CPX045045035-192-C2-R0 ATS-CPX060060010-129-C2-R0 ATS-CPX060060012-207-C2-R0 ATS-FPX060060025-25-C2-R0 ATS-CPX070070010-209-C2-R0 ATS-CPX070070010-133-C2-R0 ATS-1040-C3-R0 ATS-57003-C1-R0 ATS-57002-C1-R0 ATS-CPX025025020-167-C2-R0 ATS-CPX040040010-194-C2-R0 ATS-FPX025025015-74-C2-R0 ATS-FPX025025015-44-C2-R0 ATS-CPX040040012-195-C2-R0 ATS-FPX040040010-01-C2-R0 ATS-FPX040040013-02-C2-R0 ATS-CPX045045006-196-C2-R0 ATS-FPX030030015-50-C2-R0 ATS-CPX045045010-117-C2-R0 ATS-CPX045045010-197-C2-R0 ATS-FPX040040015-03-C2-R0 ATS-CPX045045012-198-C2-R0 ATS-CPX030030015-142-C2-R0 ATS-FPX040040020-04-C2-R0 ATS-CPX045045015-118-C2-R0 ATS-FPX030030025-52-C2-R0 ATS-FPX035035010-85-C2-R0 ATS-FPX030030025-82-C2-R0 ATS-FPX045045010-06-C2-R0 ATS-CPX030030020-171-C2-R0 ATS-CPX030030020-143-C2-R0 ATS-CPX045045020-119-C2-R0 ATS-FPX045045013-07-C2-R0 ATS-CPX030030025-172-C2-R0 ATS-FPX035035015-56-C2-R0 ATS-FPX045045015-08-C2-R0 ATS-FPX025025035-48-C2-R0 ATS-FPX040040010-61-C2-R0 ATS-CPX030030030-145-C2-R0 ATS-CPX035035015-176-C2-R0 ATS-CPX030030035-146-C2-R0 ATS-CPX030030035-174-C2-R0 ATS-CPX040040010-181-C2-R0 ATS-FPX035035025-88-C2-R0 ATS-CPX054054006-202-C2-R0 ATS-FPX040040015-92-C2-R0 ATS-FPX045045025-10-C2-R0 ATS-CPX035035025-178-C2-R0 ATS-FPX050050015-13-C2-R0 ATS-CPX054054010-125-C2-R0 ATS-CPX040040015-154-C2-R0 ATS-CPX040040015-182-C2-R0 ATS-FPX030030035-84-C2-R0 ATS-FPX030030035-54-C2-R0 ATS-CPX035035030-151-C2-R0 ATS-CPX040040020-183-C2-R0 ATS-CPX040040020-155-C2-R0 ATS-FPX050050020-14-C2-R0 ATS-CPX054054015-126-C2-R0 ATS-FPX040040020-63-C2-R0 ATS-CPX035035035-152-C2-R0 ATS-CPX040040025-184-C2-R0 ATS-FPX054054010-16-C2-R0 ATS-CPX045045010-187-C2-R0 ATS-FPS037058006-35-C2-R0 ATS-CPX040040030-157-C2-R0 ATS-CPX040040030-185-C2-R0 ATS-FPX040040025-94-C2-R0 ATS-FPX035035030-59-C2-R0 ATS-CPX045045015-188-C2-R0 ATS-CPX045045015-160-C2-R0 ATS-FPX035035035-90-C2-R0 ATS-FPX035035035-60-C2-R0 ATS-CPX040040035-158-C2-R0 ATS-P1-02-C2-R0 ATS-FPX040040013-104-C2-R1 ATS-FPX040040010-103-C2-R1 ATS-FPX045045020-99-C2-R0 ATS-P1-04-C2-R0 ATS-FPX054054020-19-C2-R0 ATS-FPS058037018-33-C2-R0 ATS-FPX040040030-65-C2-R0 ATS-CPX045045025-162-C2-R0 ATS-CPX045045025-190-C2-R0 ATS-FPS037058018-37-C2-R0 ATS-P1-05-C2-R0 ATS-CPX045045030-191-C2-R0 ATS-FPX045045025-70-C2-R0 ATS-FPX040040035-96-C2-R0 ATS-CPX060060006-205-C2-R0 ATS-FPX040040035-66-C2-R0 ATS-FPX054054025-20-C2-R0 ATS-P1-08-C2-R0 ATS-FPX045045010-105-C2-R1 ATS-CPX045045035-164-C2-R0 ATS-CPX060060010-206-C2-R0 ATS-FPX045045013-106-C2-R1 ATS-FPX050050013-108-C2-R1 ATS-P1-11-C2-R0 ATS-P1-09-C2-R0 ATS-P2-01-C2-R0 ATS-P2-03-C2-R0 ATS-P1-10-C2-R0 ATS-FPX050050010-107-C2-R1 ATS-P2-02-C2-R0 ATS-P1-13-C2-R0 ATS-FPX045045030-101-C2-R0 ATS-P2-04-C2-R0 ATS-P2-06-C2-R0 ATS-P1-14-C2-R0 ATS-P2-05-C2-R0 ATS-FPX045045035-102-C2-R0 ATS-FPX045045035-72-C2-R0 ATS-P2-08-C2-R0 ATS-P1-16-C2-R0 ATS-FPX060060010-21-C2-R0 ATS-P1-15-C2-R0 ATS-FPX054054013-110-C2-R1 ATS-P2-11-C2-R0 ATS-P2-09-C2-R0 ATS-FPS058061018-41-C2-R0 ATS-P2-10-C2-R0 ATS-FPX060060020-24-C2-R0 ATS-P2-15-C2-R0 ATS-P1-107-C2-R1 ATS-P1-108-C2-R1 ATS-P2-103-C2-R1 ATS-P2-19-C2-R0 ATS-P1-31-C2-R0 ATS-P1-21-C2-R0 ATS-P1-23-C2-R0 ATS-P1-32-C2-R0 ATS-P2-108-C2-R1 ATS-FPX060060010-111-C2-R1 ATS-FPX060060013-112-C2-R1 ATS-P1-34-C2-R0 ATS-P1-38-C2-R0 ATS-H1-02-C2-R0 ATS-P2-21-C2-R0 ATS-H1-03-C2-R0 ATS-P2-23-C2-R0 ATS-P2-22-C2-R0 ATS-P1-25-C2-R0 ATS-H1-04-C2-R0 ATS-H1-05-C2-R0 ATS-H1-07-C2-R0 ATS-P1-40-C2-R0 ATS-H1-11-C2-R0 ATS-H1-09-C2-R0 ATS-P2-31-C2-R0 ATS-FPX070070013-27-C2-R0 ATS-H1-12-C2-R0 ATS-H1-13-C2-R0 ATS-P2-25-C2-R0 ATS-P2-32-C2-R0 ATS-P2-36-C2-R0 ATS-H1-14-C2-R0 ATS-FPX070070015-28-C2-R0 ATS-P1-111-C2-R1 ATS-P2-33-C2-R0 ATS-H1-16-C2-R0 ATS-H1-15-C2-R0 ATS-P2-34-C2-R0 ATS-P1-42-C2-R0 ATS-P2-38-C2-R0 ATS-H1-104-C2-R1 ATS-H1-103-C2-R1 ATS-H1-19-C2-R0 ATS-FPX070070020-29-C2-R0 ATS-P1-27-C2-R0 ATS-H1-108-C2-R1 ATS-P2-41-C2-R0 ATS-H1-21-C2-R0 ATS-1041-C3-R0 ATS-1041-C1-R0 ATS-H1-23-C2-R0 ATS-H1-109-C2-R1 ATS-P2-28-C2-R0 ATS-P1-29-C2-R0 ATS-H1-25-C2-R0 ATS-P2-29-C2-R0 ATS-1042-C2-R0 ATS-1042-C3-R0 ATS-H1-112-C2-R1 ATS-P2-30-C2-R0 ATS-H1-28-C2-R0 ATS-H1-35-C2-R0 ATS-H1-32-C2-R0 ATS-H1-36-C2-R0 ATS-H1-29-C2-R0 ATS-H1-39-C2-R0 ATS-H1-30-C2-R0 ATS-1043-C2-R0 ATS-H1-42-C2-R0 ATS-H1-168-C2-R0 ATS-1038-C2-R0 ATS-1039-C2-R0 ATS-1039-C1-R0 ATS-1043-C1-R0 ATS-1043-C3-R0 ATS-57001-C1-R0 ATS-CPX025025025-140-C2-R0 ATS-FPX025025035-78-C2-R0 ATS-CPX070070012-210-C2-R0 ATS-FPX025025025-46-C2-R0 ATS-CPX030030010-141-C2-R0 ATS-CPX035035010-147-C2-R0 ATS-FPX050050013-12-C2-R0 ATS-FPX040040020-93-C2-R0 ATS-CPX045045030-163-C2-R0 ATS-CPX060060015-130-C2-R0 ATS-FPX060060013-22-C2-R0 ATS-P1-30-C2-R0 ATS-CPX050050025-124-C3-R0
