Finding Toothless Alligator Clips with Banana Socket
I am looking for toothless alligator clips with a built-in 2mm or 4mm banana socket.
I can find alligator clips with teeth and a 4mm banana socket from Pomona: 501-1849-ND - GATOR CLIP STEEL INSULATED 5A
I can find alligator clips without teeth, but also without a banana socket from Mueller: 314-1388-ND - GATOR CLIP SS NON-INSUL 5A
I can’t find a clip both without teeth and with a banana socket.
Insulation / clip cover is optional.
Material / plating is not important.
2mm or 4mm banana socket size.
Alligator clip size not important.
Does anyone know if these exist?
Thanks,
Samuel
Welcome to the DigiKey TechForum. I wasn’t successful in finding a banana to toothless alligator adapter but you may be able put a wire between part 314-1017-ND and part 501-1348-ND and make your own adapter.
Thanks for the response, I’ll look in to making our own clips from other parts like you suggested.
