Looking for the above flex cable 20861 awm 105c 60v vw-1
Is there an equivilent?
Hello kvanjaa,
Welcome to the DigiKey TechForum community.
Based on the info I found these 20861 seem to be 30pin/conductor FFC cable at 0.5mm pitch. We have some similar cables of differing lengths in link:
Hope that helps. If you have a requirement for different conductor count at that pitch you can select proper conductor number in link here.
Regards,
