does anyone know these / this spring contact ? they make contact with the spring on the cover for bat power supply.. brand Hilti
thank you
Hello docgeng,
If you are able to take some measurements and post the results/pictures here that will greatly assist us in identifying this component.
Regards,
Klint
I don’t think it’s going to be in battery contacts. I believe it would be in Spring Loaded | Rectangular Connectors
But I don’t see a visual match to what you have.
Hello docgeng,
I’m sorry, but I do not see a match to this connector, in DigiKey’s system.
Thank you david, N.A. is an answer too.
Eventually is doesnt have to be 100% the same. as long as it does the job ![]()
If desperate, perhaps you could hack (as in hacksaw) something together with one of these?
1827928-1 3-Position Spring Battery Contact, 3.2mm pitch
1746142-1 3-Position Spring Battery Contact, 3.2mm pitch
If those won’t work, here’s the link to the whole spring-loaded connector section of normally-stocking parts to look through.
