This Product Selection Guide contains information to help select products in the Heat Guns, Torches, Accessories category on DigiKey.com
Heat Guns, Torches, and accessories are tools used to apply heat via emitted hot air, radiated energy, or a direct flame, along with the supplementary items used with them. They are similar in shape and construction to a hair dryer, though they run at much higher temperatures 40°F (4.4°C) to 3729°F (2054°C). The tool types are a bed heater, belt heater, butane torch, compressed air heater, CV-Obhat Stub, discrete heater, heat blower, heat gun, infrared heater, propane torch, and tunnel oven.
SelectionCharacteristics
Tool Type: The type, style, or form factor of the heat tool, for heat tools within this category.
Accessory Type: The type of accessory being offered, for accessory parts within this category.
Temperature Range: The temperature or range of temperatures the heat tool can generate.
Voltage: The supply voltage the heat tool requires to function correctly.
Current: The supply current the heat tool requires to function correctly.
Power-Rated: Indicates the nominal maximum power consumption of a device.
Includes: Describes which subcomponents a given heat tool is shipped with when ordered.
For Use With/Related Products: The product or products the device is an accessory for, for accessories in this category.
Compatible Tools: Indicates tools with which an accessory is intended for use.
Features: Special features or functions the device includes.
Approval Agency Marking: Enumerates the certification body approval and/or standards conformity declaration marks carried by a product.
Approved Countries: Indicates the nations for which a device carries relevant approvals or declarations of conformity.
Nozzle Opening: The diameter of the opening in the tool’s nozzle that controls airflow from the tool.
Air Flow: Characterizes the maximum air volume flow rate a device can generate. Usually measured under conditions of rated voltage and zero pressure difference between a device’s inlet and outlet.
Color: Dominant color of the device.
ProductExamples
| MFR PART # | 110025596 |
| DIGI-KEY PART # | 110025596-ND |
| MANUFACTURER | Steinel America |
| DESCRIPTION | Heat Gun 120V 120°F ~ 1100°F (49°C ~ 593°C) 1500W Black, Gray |
| MFR PART # | AO8032A++ |
| DIGI-KEY PART # | 2260-AO8032A+±ND |
| MANUFACTURER | SRA Soldering Products |
| DESCRIPTION | Heat Gun 110V 212°F ~ 896°F (100°C ~ 480°C) 550W Black |
| MFR PART # | MT-11 |
| DIGI-KEY PART # | MT-11-ND |
| MANUFACTURER | Master Appliance Co |
| DESCRIPTION | Butane Torch, Hand-Held 2500°F (1371°C) Red |
| MFR PART # | 30083 |
| DIGI-KEY PART # | 133-30083-ND |
| DESCRIPTION | Heating Element Kit 120V 1200°F (649°C) 1740W |
| MFR PART # | 6965A |
| DIGI-KEY PART # | 6965A-ND |
| MANUFACTURER | Apex Tool Group |
| DESCRIPTION | Stand Silver |
| MFR PART # | 2234786-1 |
| DIGI-KEY PART # | 2132-2234786-1-ND |
| MANUFACTURER | TE Application Tooling |
| DESCRIPTION | Processor, Bench Top, Semi-Automatic Cable Clamp |
MediaLinks
Videos
Digi-Key Content Library - Heat Guns
Product Training Modules
Electronic Heat Gun Series - Steinel
TechForum
Safety Operating Heat Guns
