Help Identifying Edge-Mount Tactile Switch Replacement
Hi everyone,
I’m trying to identify a replacement for a surface-mount, side-actuated tactile switch I found on a small PCB. It’s labelled “S15” on the board, and it appears to be edge-mounted with gull-wing leads. The button protrudes slightly from the edge of the board for side access.
Any help matching the footprint and specs would be massively appreciated!
Thanks in advance.
Tomas
Hello tomas.darcy01 and welcome to the DigiKey TechForum.
Visually, it does look a bit like EG4389TR-ND, but without knowing function, circuit, any electrical ratings, and dimensions it would be a guess that is just based on appearances.
Thanks, Nick! That’s exactly what I needed. Really appreciate you pointing me in the right direction.
Cheers
Tomas
