I need a battery pack with a 10KΩ NTC thermistor with Beta Value of 3977K.
What does the HHR-150AAB01F3(Digikey part # P015-F031-ND) have in it?
Welcome to the Digi-Key TechForum bthibodeau.
We do not have access to what is used with the battery packs.
You can contact the custom department at custom.orders@digikey.com, and see if they will give you that information. You can also request if it would be possible to get one made with the correct thermistor. A possible match would be 570-1215-ND.
Please check the datasheet to verify compatibility.
Thank you so much, I have reached out to the custom orders department and hopefully they can supply that info.
Cheers!
