Thermistor
I need a thermistor, 10kohm ntc b25/50 3900 to 3950. I need one with leads or I need to solder leads to it. Can I solder leads to the thermistor without damaging it. Can you guys/ladies recommend a thermistor that will work? I need 6-8’ leads, this is for a battery temp sensor. Thank you for all of your help. John
Take a look at the link below for some part numbers you can look at.
https://www.digikey.com/en/products/filter/temperature-sensors-ntc-thermistors/508?s=N4IgjCBcoBwGwCYqgMZQGYEMA2BnApgDQgD2UA2iAgAzUDsdExNY1c1Iz1rcArJ1W7UAnAGYBLMKKQBdYgAcALlBABlRQCcAlgDsA5iAC%2BxeHGQg0kLHiKkKIOqIAs1cXJBKV67fqPEAtEjQFlCaAK62ZJCU-DKGxlT2igAW%2BBoAtlq4iiQaAAQA7loa%2BHnY%2BJgAJiBxQA
Thank you Karl!
Thank you Karl! Can I solder leads to the thermistor without leads? I already ordered them. Thank you
Yes you can do that.
Thank you Karl!
