would you provide the detail of the flat cable connector in HM0360-MWA-00FP963?
Such as the connector type, pin assignment, pitch size, etc.
Is it possible to change the connector type?
Hi,
Welcome to the Digikey tech forum. I have sent the request to our product specialist and will post as soon as I get it.
Hello @roy.yang,
Thank you for your request. I have sent a request to the supplier and I will attach when received.
@roy.yang the supplier provided the datasheet:
HM0360-MWA-00FP963_DS_preliminary_v01.pdf (2.6 MB)
Page 15 provides the connector part number and pin assignment. The connector is a OK-10GM030-04 and has a .4 mm pitch.
That is the standard connector on that series would not be able to change the connector.
Thanks for your information.
