Honda Connector Pin
To help identify it would be extremely helpful to show the connector these contacts are used in.
Is this a good enough picture?
I was not able to find a visual match to this connector that DigiKey carries.
The most import thing needed for identification of a connector is to measure the pitch, P, of the connector. This is the center-to-center spacing of the contacts. After that, we can look at other things like general shape and other dimensions.
Measure 2P and divide by two to get a more accurate measure of P.
For 2P I measured 10mm. So 5mm for P.
Looking like the Honda part number for this might be 04321-S0X-305.
Is this for Fog Lights?
It is for the ignition coil. Thanks a bunch for all the help as well!
