Hey all. I have a question for the hive mind. I have a box of wireless LED’s here at work. We use them for event lighting for weddings and so on. You can charge all the LED’s at once by a power port on the side. And there is a rocker switch. I ordered the wrong one from DigiKey. It looks a lot like part number 4304.6094-ND.
But the back where the connectors go is totally different, plus it physically will not fit in the opening the old one came out of.
I attached/uploaded two pics of the old rocker switch. (hopefully it works) There are no part numbers or any other type of identifying info on it. So hopefully someone where can help with an ID. Thanks so much for the help! good luck!
-Dan
Hi danvotta
What are the panel cutout dimensions of the part you are replacing?
Hi @danvotta ,
Would this fit? (Unfortunately no dimensions given).
https://www.etsy.com/listing/1082927732/safety-ac-power-socket-with-back-cover
Cheers, heke
