Housing + Connector Replacement
Looking for some help in identifying what this housing might be called that fits on J16? For reference this is a Balboa Spa Pack. The area, J17, on top of it uses the same housing and connector for reference. I’ve had no luck finding anything that matches the 2 anchor asymmetrical layout that’s on this board.
Thank you in advance
Welcome to the TechForum Cellutions! It sort of looks like they had planned for room for a second sensor (SNSR_B). It seems like it may have been ripped off or something as there are pins located in that area. Do you have any markings for the connector above? Do you have any dimensions of the connector and header? The most common dimension is the pitch between pins that plug into the connector on the board (the center to center distance). Pictures of just the mates would help too.
