ID Connector
Hello, can you help ID this connector. The mounting holes are 15mm apart the pin spacing is 2.54mm. There are numbers 570 and 3590 on the part.
Thank you
Gary
Hello gary,
We do not have a match to this connector. I also did some searching on the internet, and I did not find any information on this connector.
I’m sorry, but I was unable to identify this connector.
Hello gary,
Are you able to provide what board this connector is on or what the connector is used for? We might be able to find a cross or get something close with a little more context.
Regards,
Klint
This is a LED board, turn signal for vehicle. Looks like it is some kind of blind mate connector. I assume the holes align to pins on the receptical side.
Thanks
Gary
The mating connector is a JAE MX19A003S51. But I cant find this side.
Thanks
Gary
The datasheet for that part is showing a different mate. The connector you have might be custom-made for the application.
