How to connect Honeywell CSNK500M Current Sensors
When looking at the electrical connections of CSN series Current Sensors from Honeywell, it only shows how the sensor are connected, depending on whether a bipolar (+/-) or unipolar (+/0) power supply is required by the sensor.
sensor
But the pinouts of the device do not call out in the datasheet, such as CSNK500M. How to connect this current sensor?
Here is the pin assignment of CSNK500M.
CSKN500
  • Connector Molex 0022292031 or equivalent is integrated in CSNK500M current sensor
When mating CSNK500M current sensor, you can try to use the mating connector of 0022292031 at Here.
Applicable part number
CSNK500M
480-4832-ND
